# # ChangeLog for memlog2dot # # Generated by Trac 0.12.5 # 05/07/25 04:23:58 Sat, 30 May 2015 00:05:23 GMT Hal Finkel [20b45de] * memlog2dot (modified) add a txt output too for analysis Fri, 29 May 2015 12:53:00 GMT Hal Finkel [1bd82e0] * Makefile (modified) * memlog.cpp (moved) * memlog2dot (modified) adjust for c++, use caching of dladdr, fixup for short names when making ... Fri, 29 May 2015 08:30:33 GMT Hal Finkel [bdaf020] * memlog2dot (modified) better legend Fri, 29 May 2015 07:30:00 GMT Hal Finkel [747d2b1] * memlog2dot (modified) get newer binutils; we do have them at ALCF Fri, 29 May 2015 07:16:47 GMT Hal Finkel [10599da] * memlog2dot (modified) add comment on @ Fri, 29 May 2015 02:40:15 GMT Hal Finkel [081a0fa] * memlog2dot (modified) don't print file:line if it is unknown (even if we have the function ... Thu, 28 May 2015 23:45:11 GMT Hal Finkel [0edbc98] * memlog2dot (modified) only process allocations at the high-water mark Thu, 28 May 2015 23:15:39 GMT Hal Finkel [6bfe6a1] * memlog2dot (modified) don't print raw proc names by default Thu, 28 May 2015 23:09:28 GMT Hal Finkel [81dea5b] * memlog2dot (modified) do the whole pdf conversion Thu, 28 May 2015 22:50:41 GMT Hal Finkel [6520ef5] * memlog2dot (modified) fix edge font sizes and function printing Thu, 28 May 2015 22:09:31 GMT Hal Finkel [c4f89cf] * memlog2dot (modified) common nodes correctly Thu, 28 May 2015 21:48:52 GMT Hal Finkel [4bd7a88] * memlog2dot (modified) working on filtering nodes... Thu, 28 May 2015 20:46:25 GMT Hal Finkel [ebd57f8] * memlog2dot (added) initial graphing tool
