# # ChangeLog for README # # Generated by Trac 0.12.5 # 05/17/24 00:32:51 Wed, 03 Jun 2015 15:23:56 GMT Hal Finkel [3c9fc94] * Makefile (modified) * README (modified) add ld cmds file Tue, 02 Jun 2015 23:53:15 GMT Hal Finkel [ed8b809] * README (modified) * memlog.cpp (modified) fixup the wrapping of mmap, etc. Mon, 01 Jun 2015 12:14:28 GMT Hal Finkel [192a260] * README (modified) add a directory note to the README Mon, 01 Jun 2015 11:25:13 GMT Hal Finkel [5df7203] * README (modified) * memlog_analyze (modified) add glob processing Mon, 01 Jun 2015 11:00:01 GMT Hal Finkel [0109b01] * README (modified) note --leaks in the README Mon, 01 Jun 2015 09:56:55 GMT Hal Finkel [4598848] * Makefile (modified) * README (modified) * memlog_analyze (moved) rename memlog2dot to memlog_analyze Sun, 31 May 2015 14:46:11 GMT Hal Finkel [22f928f] * README (modified) * memlog.cpp (modified) use the job id under batch systems; misc cleanups Sat, 30 May 2015 01:38:43 GMT Hal Finkel [24aa734] * README (modified) note in the README that a txt file is also generated Fri, 29 May 2015 19:08:02 GMT Hal Finkel [af4bfd0] * README (added) add a README
