# # ChangeLog for Makefile # # Generated by Trac 0.12.5 # 05/05/25 23:42:38 Mon, 01 Jun 2015 09:56:55 GMT Hal Finkel [4598848] * Makefile (modified) * README (modified) * memlog_analyze (moved) rename memlog2dot to memlog_analyze Sun, 31 May 2015 04:54:09 GMT Hal Finkel [a7b97b9] * Makefile (modified) * memlog.cpp (modified) use kernel rank on the bgq instead of pid Fri, 29 May 2015 20:57:42 GMT Hal Finkel [510af01] * Makefile (modified) add an install target to the makefile Fri, 29 May 2015 13:31:35 GMT Hal Finkel [e1b15ec] * Makefile (modified) adjust the makefile to work with slightly-older gcc Fri, 29 May 2015 12:53:00 GMT Hal Finkel [1bd82e0] * Makefile (modified) * memlog.cpp (moved) * memlog2dot (modified) adjust for c++, use caching of dladdr, fixup for short names when making ... Fri, 29 May 2015 07:39:15 GMT Hal Finkel [493cb97] * Makefile (modified) * memlog.c (modified) static linking comment; make static .o memlog_s.o Fri, 29 May 2015 02:24:13 GMT Hal Finkel [430548b] * Makefile (modified) * memlog.c (modified) a working solution for static linking Fri, 29 May 2015 00:04:06 GMT Hal Finkel [fc0b9bf] * Makefile (modified) make building with gcc work too Fri, 29 May 2015 00:02:02 GMT Hal Finkel [65ecf6c] * Makefile (modified) make these things named libmemlog.* Thu, 28 May 2015 17:50:12 GMT Hal Finkel [14e2ab9] * Makefile (modified) * memlog.c (modified) rm support for libunwind; only using backtrace() now Thu, 28 May 2015 13:00:26 GMT Hal Finkel [0a0ef57] * Makefile (modified) * memlog.c (modified) unw_get_proc_info does not work on ppc/ppc64; add getrusage info Thu, 28 May 2015 12:14:49 GMT Hal Finkel [0ec59c5] * Makefile (added) * memlog.c (added) Commit something that compiles
