# # ChangeLog for / # # Generated by Trac 0.12.5 # 05/06/24 04:19:31 Fri, 29 May 2015 00:02:02 GMT Hal Finkel [65ecf6c] * Makefile (modified) make these things named libmemlog.* Thu, 28 May 2015 23:45:11 GMT Hal Finkel [0edbc98] * memlog2dot (modified) only process allocations at the high-water mark Thu, 28 May 2015 23:15:39 GMT Hal Finkel [6bfe6a1] * memlog2dot (modified) don't print raw proc names by default Thu, 28 May 2015 23:09:28 GMT Hal Finkel [81dea5b] * memlog2dot (modified) do the whole pdf conversion Thu, 28 May 2015 22:50:41 GMT Hal Finkel [6520ef5] * memlog2dot (modified) fix edge font sizes and function printing Thu, 28 May 2015 22:09:31 GMT Hal Finkel [c4f89cf] * memlog2dot (modified) common nodes correctly Thu, 28 May 2015 21:48:52 GMT Hal Finkel [4bd7a88] * memlog2dot (modified) working on filtering nodes... Thu, 28 May 2015 20:46:25 GMT Hal Finkel [ebd57f8] * memlog2dot (added) initial graphing tool Thu, 28 May 2015 18:23:10 GMT Hal Finkel [625d5f9] * memlog.c (modified) just use .memlog as the suffix Thu, 28 May 2015 17:57:39 GMT Hal Finkel [97550d2] * memlog.c (modified) some extra portability, perhaps, by using __builtin_extract_return_addr Thu, 28 May 2015 17:50:12 GMT Hal Finkel [14e2ab9] * Makefile (modified) * memlog.c (modified) rm support for libunwind; only using backtrace() now Thu, 28 May 2015 17:14:39 GMT Hal Finkel [a736d81] * memlog.c (modified) use backtrace instead Thu, 28 May 2015 17:09:35 GMT Hal Finkel [69850c8] * memlog.c (modified) trying to avoid using unw_get_proc_name, etc. Thu, 28 May 2015 13:18:21 GMT Hal Finkel [134408c] * memlog.c (modified) print tid; break on UNW_ENOINFO Thu, 28 May 2015 13:00:26 GMT Hal Finkel [0a0ef57] * Makefile (modified) * memlog.c (modified) unw_get_proc_info does not work on ppc/ppc64; add getrusage info Thu, 28 May 2015 12:14:49 GMT Hal Finkel [0ec59c5] * Makefile (added) * memlog.c (added) Commit something that compiles
