# # ChangeLog for / # # Generated by Trac 0.12.5 # 11/22/24 03:55:06 Mon, 25 Sep 2017 21:15:39 GMT Hal Finkel [5d57155] * GenericIO.cxx (modified) * GenericIO.h (modified) * GenericIOBenchmarkRead.cxx (modified) * GenericIOBenchmarkWrite.cxx (modified) * GenericIOPrint.cxx (modified) Add support for float4 (and other homogeneous aggregates) Mon, 29 Aug 2016 16:06:24 GMT Hal Finkel [fb69232] * GNUmakefile (modified) rm the .pyc when you make clean Mon, 29 Aug 2016 15:47:09 GMT Hal Finkel [c13d973] * python/example.py (modified) * python/genericio.py (moved) Fixup genericio python to be more path independent Sat, 27 Aug 2016 01:43:19 GMT Hal Finkel [63c7ac7] * python/example.py (modified) Add license to example.py Sat, 27 Aug 2016 01:42:36 GMT Hal Finkel [ef727a6] * GNUmakefile (modified) * python/example.py (added) * python/gio.py (modified) Some python cleanups and an example Sat, 27 Aug 2016 01:30:22 GMT Hal Finkel [bd84570] * GNUmakefile (modified) * python/gio.py (added) * python/lib/gio.cxx (added) * python/lib/gio.h (added) Add simple python interface from Dan Sat, 27 Aug 2016 01:03:18 GMT Hal Finkel [95f86a3] * GenericIORewrite.cxx (modified) drop gio topology column tags when not preserving topology Sat, 27 Aug 2016 01:03:03 GMT Hal Finkel [7ff84e0] * GenericIORewrite.cxx (modified) When rewriting, allow for redistribution; preserve topology info when a ... Sat, 27 Aug 2016 01:02:28 GMT Hal Finkel [fc4fc2f] * GNUmakefile (modified) * GenericIORewrite.cxx (added) add a GIO rewriter (to compress files, etc.) Sat, 27 Aug 2016 00:58:52 GMT Hal Finkel [8ebc79b] * GNUmakefile (modified) * thirdparty/blosc/internal-complibs/lz4-1.7.2/lz4.c (added) * thirdparty/blosc/internal-complibs/lz4-1.7.2/lz4.h (added) * thirdparty/blosc/internal-complibs/lz4-1.7.2/lz4hc.c (added) * thirdparty/blosc/internal-complibs/lz4-1.7.2/lz4hc.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/add-version.patch (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/msvc1.patch (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/msvc2.patch (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-c.cxx (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-c.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-internal.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-sinksource.cxx (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-sinksource.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-stubs-internal.cxx (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-stubs-internal.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy-stubs-public.h (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy.cxx (added) * thirdparty/blosc/internal-complibs/snappy-1.1.1/snappy.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/adler32.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/compress.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/crc32.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/crc32.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/deflate.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/deflate.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/gzclose.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/gzguts.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/gzlib.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/gzread.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/gzwrite.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/infback.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inffast.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inffast.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inffixed.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inflate.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inflate.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inftrees.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/inftrees.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/trees.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/trees.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/uncompr.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/zconf.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/zlib.h (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/zutil.c (added) * thirdparty/blosc/internal-complibs/zlib-1.2.8/zutil.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/LICENSE (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/README.md (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/bitstream.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/entropy_common.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/error_private.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/error_public.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/fse.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/fse_decompress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/huf.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/mem.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/xxhash.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/xxhash.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/zbuff.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/zstd.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/zstd_common.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/common/zstd_internal.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/.debug/zstd_stats.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/fse_compress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/huf_compress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/zbuff_compress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/zstd_compress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/compress/zstd_opt.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/decompress/huf_decompress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/decompress/zbuff_decompress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/decompress/zstd_decompress.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/dictBuilder/divsufsort.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/dictBuilder/divsufsort.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/dictBuilder/zdict.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/dictBuilder/zdict.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_legacy.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v01.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v01.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v02.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v02.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v03.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v03.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v04.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v04.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v05.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v05.h (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v06.c (added) * thirdparty/blosc/internal-complibs/zstd-0.7.4/legacy/zstd_v06.h (added) Add the other internal compression libraries from blocs Sat, 27 Aug 2016 00:35:26 GMT Hal Finkel [981e22c] * GNUmakefile (modified) * thirdparty/blosc/ANNOUNCE.rst (modified) * thirdparty/blosc/LICENSES/BITSHUFFLE.txt (added) * thirdparty/blosc/LICENSES/BLOSC.txt (modified) * thirdparty/blosc/LICENSES/LZ4.txt (added) * thirdparty/blosc/LICENSES/SNAPPY.txt (added) * thirdparty/blosc/LICENSES/STDINT.txt (modified) * thirdparty/blosc/LICENSES/ZLIB.txt (added) * thirdparty/blosc/README.rst (modified) * thirdparty/blosc/README_HEADER.rst (modified) * thirdparty/blosc/RELEASE_NOTES.rst (modified) * thirdparty/blosc/RELEASING.rst (modified) * thirdparty/blosc/THANKS.rst (added) * thirdparty/blosc/bitshuffle-generic.c (added) * thirdparty/blosc/bitshuffle-generic.h (added) * thirdparty/blosc/blosc-export.h (added) * thirdparty/blosc/blosc.c (modified) * thirdparty/blosc/blosc.h (modified) * thirdparty/blosc/blosclz.c (modified) * thirdparty/blosc/blosclz.h (modified) * thirdparty/blosc/shuffle-common.h (added) * thirdparty/blosc/shuffle-generic.c (added) * thirdparty/blosc/shuffle-generic.h (added) * thirdparty/blosc/shuffle.c (modified) * thirdparty/blosc/shuffle.h (modified) Upgrade to latest blosc library blosc git: ... Sat, 27 Aug 2016 00:28:54 GMT Hal Finkel [cda87e9] * GenericIOBenchmarkWrite.cxx (modified) The GIO write benchmark should not use completely trivial data (so ... Sat, 27 Aug 2016 00:28:29 GMT Hal Finkel [72ac664] * GenericIOBenchmarkWrite.cxx (modified) Optionally, the GIO write benchmark should create compressed files Sat, 27 Aug 2016 00:22:00 GMT Hal Finkel [754e14c] * GNUmakefile (modified) Use -fopenmp with the MPI compiles too Wed, 13 Apr 2016 00:22:09 GMT Hal Finkel [14e73bb] * GenericIO.cxx (modified) * GenericIO.h (modified) Misc. improvements to splitting and error handling Wed, 13 Apr 2016 00:18:46 GMT Hal Finkel [8f0a211] * GenericIO.cxx (modified) * GenericIO.h (modified) * GenericIO2Cosmo.cxx (modified) * GenericIOBenchmarkRead.cxx (modified) * GenericIOPrint.cxx (modified) * GenericIOVerify.cxx (modified) Add redistribution support Sat, 10 Oct 2015 00:14:02 GMT Hal Finkel [a4fee13] * GenericIO.cxx (modified) * GenericIO.h (modified) Implement reading of files of non-native Endianness Fri, 02 Oct 2015 19:59:35 GMT Hal Finkel [406b50a] * GNUmakefile (modified) Add simple benchmark programs to the makefile Fri, 02 Oct 2015 19:55:00 GMT Hal Finkel [ba0fbd1] * GenericIOBenchmarkRead.cxx (added) * GenericIOBenchmarkWrite.cxx (added) Add some simple benchmark programs Mon, 08 Jun 2015 17:51:46 GMT Hal Finkel [da65757] * CRC64.h (modified) * GNUmakefile (modified) * GenericIO.cxx (modified) * GenericIO.h (modified) * GenericIO2Cosmo.cxx (modified) * GenericIOPrint.cxx (modified) * GenericIOSQLite.cxx (modified) * GenericIOVerify.cxx (modified) add license to all files Mon, 08 Jun 2015 17:44:47 GMT Hal Finkel [1326998] * COPYING (added) add approved license in the COPYING file Fri, 15 May 2015 22:55:09 GMT Hal Finkel [00587dc] * CRC64.h (added) * GNUmakefile (added) * GenericIO.cxx (added) * GenericIO.h (added) * GenericIO2Cosmo.cxx (added) * GenericIOPrint.cxx (added) * GenericIOSQLite.cxx (added) * GenericIOVerify.cxx (added) * thirdparty/blosc/.gitignore (added) * thirdparty/blosc/ANNOUNCE.rst (added) * thirdparty/blosc/LICENSES/BLOSC.txt (added) * thirdparty/blosc/LICENSES/FASTLZ.txt (added) * thirdparty/blosc/LICENSES/H5PY.txt (added) * thirdparty/blosc/LICENSES/STDINT.txt (added) * thirdparty/blosc/README.rst (added) * thirdparty/blosc/README_HEADER.rst (added) * thirdparty/blosc/README_THREADED.rst (added) * thirdparty/blosc/RELEASE_NOTES.rst (added) * thirdparty/blosc/RELEASING.rst (added) * thirdparty/blosc/blosc.c (added) * thirdparty/blosc/blosc.h (added) * thirdparty/blosc/blosclz.c (added) * thirdparty/blosc/blosclz.h (added) * thirdparty/blosc/shuffle.c (added) * thirdparty/blosc/shuffle.h (added) * thirdparty/sqlite/shell.c (added) * thirdparty/sqlite/sqlite3.c (added) * thirdparty/sqlite/sqlite3.h (added) * thirdparty/sqlite/sqlite3ext.h (added) Initial Commit (gio-base-20150317)
